跳转到主内容
  1. Flip the laptop over. Using a Phillips #1 screwdriver, remove the five 5.65 mm screws.
    • Flip the laptop over.
    • Using a Phillips #1 screwdriver, remove the five 5.65 mm screws.
    • The screw that holds the RAM compartment cover may be permanently connected. This screw is the center most screw of the five.
    • Be sure to have a designated place to hold the different sized screws removed in this guide.
  2. Remove the lid to the RAM compartment, if possible. To remove the RAM, depress the tabs that are holding it in. These tabs are bound in red in the picture. Use a spudger to unclip the edges of the cover if necessary.
    • Remove the lid to the RAM compartment, if possible.
    • To remove the RAM, depress the tabs that are holding it in. These tabs are bound in red in the picture.
    • Use a spudger to unclip the edges of the cover if necessary.
    • The battery is shown still attached in the picture, but it should be removed prior to beginning this guide.
  3. Use a Phillips #1 screwdriver to remove one 6.5 mm screw located next to the RAM.
    • Use a Phillips #1 screwdriver to remove one 6.5 mm screw located next to the RAM.
  4. Flip the laptop back over, and open the display. Use a Phillips #1 screwdriver to remove the six 5.5 mm screws on the inside covering.
    • Flip the laptop back over, and open the display.
    • Use a Phillips #1 screwdriver to remove the six 5.5 mm screws on the inside covering.
  5. iPhone 电池维修工具包
    只要 $29.99
    Buy Now
    iPhone 电池维修工具包
    只要 $29.99
    Buy Now
  6. Detach the five plastic clips holding the upper and lower halves of the laptop together. These can be undone by carefully running a plastic opening tool between the top and bottom casing. There will be an audible audible "click" as the clips come undone. The top plastic is fragile. There are also two miniature LEDs exposed along the top edge of the bottom casing at the bottom right that are easily damaged.
    • Detach the five plastic clips holding the upper and lower halves of the laptop together. These can be undone by carefully running a plastic opening tool between the top and bottom casing. There will be an audible audible "click" as the clips come undone.
    • The top plastic is fragile. There are also two miniature LEDs exposed along the top edge of the bottom casing at the bottom right that are easily damaged.
    • Once the five clips have been undone, carefully remove the upper half of the laptop.
  7. Detach the track pad ribbon by using a plastic opening tool to raise up the black pad.
    • Detach the track pad ribbon by using a plastic opening tool to raise up the black pad.
  8. Detach the Bluetooth wire located below the fan by gently pulling it upward. Detach the Bluetooth wire located below the fan by gently pulling it upward.
    • Detach the Bluetooth wire located below the fan by gently pulling it upward.
  9. Detach the ribbon cable that connects the SD card module and the motherboard by lifting the black clips using the plastic opening tool. Detach the ribbon cable that connects the SD card module and the motherboard by lifting the black clips using the plastic opening tool.
    • Detach the ribbon cable that connects the SD card module and the motherboard by lifting the black clips using the plastic opening tool.
  10. Remove the two screws holding the SD card panel in place.
    • Remove the two screws holding the SD card panel in place.
  11. Gently lift up the SD card reader from its housing.
    • Gently lift up the SD card reader from its housing.
结论
Maged Hanna
于2014年03月13日注册
685 信誉积分
创作了4篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 13
总计 2,346
