跳转到主内容
Asus Eee PC 1005HA Keyboard Replacement
你所需要的
  1. Asus Eee PC 1005HA Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Lay the laptop upside down.
    • Locate the two battery lock tabs.
  2. Asus Eee PC 1005HA Keyboard Replacement: 步骤 2 中的图像 1,3 Asus Eee PC 1005HA Keyboard Replacement: 步骤 2 中的图像 2,3 Asus Eee PC 1005HA Keyboard Replacement: 步骤 2 中的图像 3,3
    • Slide the tabs outward to unlock the battery.
    • The left tab will remain unlocked, while the right tab must be held.
    • Holding the right tab open, slide the battery out of the laptop.
  3. Asus Eee PC 1005HA Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,2 Asus Eee PC 1005HA Keyboard Replacement, Keyboard: 步骤 3 中的图像 2,2
    • Use a plastic opening tool to pull up the four metal latches in the battery cavity that is located on the bottom of the laptop.
    • Do not apply too much pressure. The latches can not be removed and will bend if forced.
  4. Asus Eee PC 1005HA Keyboard Replacement: 步骤 4 中的图像 1,3 Asus Eee PC 1005HA Keyboard Replacement: 步骤 4 中的图像 2,3 Asus Eee PC 1005HA Keyboard Replacement: 步骤 4 中的图像 3,3
    • Flip the laptop over, and open the display.
    • Use a plastic opening tool to lift the edge of the keyboard that is nearest to the screen.
    • Gently lift the keyboard and slide it toward the screen.
    • Do not remove the keyboard completely. This can damage the ribbon cable connecting the underside of the keyboard to the laptop.
  5. Asus Eee PC 1005HA Keyboard Replacement: 步骤 5 中的图像 1,1
    • Use a spudger tool to release the tabs on the ribbon cable ZIF connector that is attached to the underside of the keyboard.
    • Depending on the model, the tabs on this ZIF connector will either flip up toward the display or push out toward the display.
    • Once the ZIF connector tabs have been released, remove the keyboard.
结论
12等其他人完成本指南。
团队
Cal Poly, Team 11-22, Maness Winter 2012 Cal Poly, Team 11-22, Maness Winter 2012 的会员
CPSU-MANESS-W12S11G22
3 名成员
创作了12篇指南
一条评论
after i upgrade my bios keyboard stop working . but external keyboard working fine.. plz help
anytimerabin - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 23,399
