本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to replace or upgrade the hard drive in the Asus Eee PC 1005HA.
你所需要的
Use a plastic opening tool to pull up the four metal latches in the battery cavity that is located on the bottom of the laptop.
Flip the laptop over.
Remove the four 5.65 mm screws from the bottom of the case.
Loosen the captive screw in the RAM compartment cover.
47等其他人完成本指南。
10条评论
Good guide! Thx!
What's the biggest hard drive that will work on this netbook?
If I remember correctly, from the manufacturer, 500 GB should work. I had a WD 320 GB in it.
