当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Use a plastic opening tool to pull up the four metal latches in the battery cavity that is located on the bottom of the laptop.
Do not apply too much pressure. The latches can not be removed and will bend if forced.
Flip the laptop over, and open the display.
Use a plastic opening tool to lift the edge of the keyboard that is nearest to the screen.
Gently lift the keyboard and slide it toward the screen.
Do not remove the keyboard completely. This can damage the ribbon cable connecting the underside of the keyboard to the laptop.
Use a spudger tool to release the tabs on the ribbon cable ZIF connector that is attached to the underside of the keyboard.
Depending on the model, the tabs on this ZIF connector will either flip up toward the display or push out toward the display.
Once the ZIF connector tabs have been released, remove the keyboard.
Flip the laptop over.
Using a Phillips #1 screwdriver, remove the five 5.65 mm screws.
The screw that holds the RAM compartment cover may be permanently connected. This screw is the center most screw of the five.
Be sure to have a designated place to hold the different sized screws removed in this guide.
Remove the lid to the RAM compartment, if possible.
To remove the RAM, depress the tabs that are holding it in. These tabs are bound in red in the picture.
Use a spudger to unclip the edges of the cover if necessary.
The battery is shown still attached in the picture, but it should be removed prior to beginning this guide.
Flip the laptop back over, and open the display.
Use a Phillips #1 screwdriver to remove the six 5.5 mm screws on the inside covering.
Detach the five plastic clips holding the upper and lower halves of the laptop together. These can be undone by carefully running a plastic opening tool between the top and bottom casing. There will be an audible audible "click" as the clips come undone.
The top plastic is fragile. There are also two miniature LEDs exposed along the top edge of the bottom casing at the bottom right that are easily damaged.
Once the five clips have been undone, carefully remove the upper half of the laptop.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
