跳转到主内容
Asus EEE PC 1000HD Keyboard Replacement
你所需要的
  1. Asus EEE PC 1000HD Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Note: Prior to changing the keyboard on your laptop, be sure to have a replacement keyboard on hand.
  2. Asus EEE PC 1000HD Keyboard Replacement: 步骤 2 中的图像 1,2 Asus EEE PC 1000HD Keyboard Replacement: 步骤 2 中的图像 2,2
    • Use a metal spudger and carefully insert the end of the flat tip into the edge of the keyboard.
    • Hold one end of the keyboard down to make prying easier.
    • Gently lift the metal spudger until you begin hearing clicking noises; these are the sounds of the keyboard unclasping from the board below.
  3. Asus EEE PC 1000HD Keyboard Replacement: 步骤 3 中的图像 1,1
    • Once you lift the keyboard, there will be a metal tab that connects the keyboard to the metal panel below.
    • Detach this metal tab slowly.
  4. Asus EEE PC 1000HD Keyboard Replacement: 步骤 4 中的图像 1,1
    • The keyboard should be fully detached.
    • With your new replacement keyboard, insert the metal tab back into the metal panel. Press gently on the keyboard to lock it into place.
    • There should be a few clicking noises as the new keyboard latches onto the metal board.
结论
Emily Gao
于10/17/17注册
101 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 551
