简介
This replacement guide instructs you in replacing the power and volume buttons. It also instructs you in removing other parts necessary to get to the buttons.
你所需要的
Remove three of the rubber feet on the bottom cover with a plastic or metal spudger.
Remove the five screws from beneath the rubber feet using a philips head screwdriver. The first 1.9mm screw is located under the front right foot, the second 1.9mm screw and third 2.3mm screw are located under the rear right foot, and the fourth and fifth 2.3mm screws are located under the rear left foot.
另外一个人完成了本指南。
