跳转到主内容
Asus Chromebook Flip C100P Power and Volume Buttons Replacement
你所需要的
  1. Asus Chromebook Flip C100P Power and Volume Buttons Replacement, Power and Volume Buttons: 步骤 1 中的图像 1,1
    • Remove three of the rubber feet on the bottom cover with a plastic or metal spudger.
  2. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 步骤 2 中的图像 1,1
    • Remove the five screws from beneath the rubber feet using a philips head screwdriver. The first 1.9mm screw is located under the front right foot, the second 1.9mm screw and third 2.3mm screw are located under the rear right foot, and the fourth and fifth 2.3mm screws are located under the rear left foot.
  3. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 步骤 3 中的图像 1,1
    • Remove the eight 3mm bottom cover screws and one 6mm screw using a T5 screwdriver. Set apart the screw in the rear middle of the bottom cover from the the other eight screws, as it is longer than them.
  4. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 步骤 4 中的图像 1,3 Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 步骤 4 中的图像 2,3 Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 步骤 4 中的图像 3,3
    • Pry the palm rest assembly apart from the bottom cover using a spudger. This step may require a bit of elbow grease. Once the palm rest has been separated from the bottom cover, pull it away from the screen, rather than away from yourself.
  5. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 步骤 5 中的图像 1,3 Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 步骤 5 中的图像 2,3 Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 步骤 5 中的图像 3,3
    • Disconnect the touchpad cable and the keyboard cable on the palm rest assembly from the motherboard using the pointed end of a plastic spudger.
  6. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 步骤 6 中的图像 1,2 Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 步骤 6 中的图像 2,2
    • Flip up the white part of the connector using the pointed end of a plastic spudge.
  7. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 步骤 7 中的图像 1,1
    • Pull the cable out by the blue tab.
  8. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 步骤 8 中的图像 1,1
    • Unscrew two 2.7 mm screws using the Phillips #0 screwdriver.
  9. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 步骤 9 中的图像 1,1
    • Remove the button chip.
  10. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 步骤 10 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using tweezers, carefully pull out the external buttons.
结论
另外一个人完成了本指南。
Andrew Thomson
于03/19/18注册
181 声望
撰写一个指南
团队
Baylor, Team S5-G2, Williams Spring 2018 Baylor, Team S5-G2, Williams Spring 2018 的会员
BU-WILLIAMS-S18S5G2
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 813
