跳转到主内容
Asus Chromebook Flip C100P Motherboard Replacement
你所需要的
  1. Asus Chromebook Flip C100P Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Remove three of the rubber feet on the bottom cover with a plastic or metal spudger.
  2. Asus Chromebook Flip C100P Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the five screws from beneath the rubber feet using a Phillips #0 screwdriver.
    • The first 1.9mm screw is located under the front right foot, the second 1.9mm screw and third 2.3mm screw are located under the rear right foot, and the fourth and fifth 2.3mm screws are located under the rear left foot.
  3. Asus Chromebook Flip C100P Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the nine bottom cover screws using a T5 screwdriver. Set apart the 6mm screw in the rear middle of the bottom cover from the the other eight 3mm screws, as it is longer than them.
    • Set apart the 6mm screw in the rear middle of the bottom cover from the the other eight 3mm screws, as it is longer than them
  4. Asus Chromebook Flip C100P Motherboard Replacement: 步骤 4 中的图像 1,3 Asus Chromebook Flip C100P Motherboard Replacement: 步骤 4 中的图像 2,3 Asus Chromebook Flip C100P Motherboard Replacement: 步骤 4 中的图像 3,3
    • Pry the palm rest assembly apart from the bottom cover using a spudger. This step may require extra power. Once the palm rest has been separated from the bottom cover, pull it away from the screen, rather than away from yourself.
  5. Asus Chromebook Flip C100P Motherboard Replacement: 步骤 5 中的图像 1,3 Asus Chromebook Flip C100P Motherboard Replacement: 步骤 5 中的图像 2,3 Asus Chromebook Flip C100P Motherboard Replacement: 步骤 5 中的图像 3,3
    • Disconnect the touchpad cable and the keyboard cable on the palm rest assembly from the motherboard using the pointed end of a plastic spudger.
  6. Asus Chromebook Flip C100P Motherboard Replacement: 步骤 6 中的图像 1,3 Asus Chromebook Flip C100P Motherboard Replacement: 步骤 6 中的图像 2,3 Asus Chromebook Flip C100P Motherboard Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Disconnect the DC jack cable and the battery cable from the motherboard using tweezers, the pointed end of a plastic spudger, or by simply pulling the cables apart from the motherboard with your fingers.
  7. Asus Chromebook Flip C100P Motherboard Replacement: 步骤 7 中的图像 1,2 Asus Chromebook Flip C100P Motherboard Replacement: 步骤 7 中的图像 2,2
    • Disconnect the LCD cable from the motherboard using the pointed end of a plastic spudger.
  8. Asus Chromebook Flip C100P Motherboard Replacement: 步骤 8 中的图像 1,2 Asus Chromebook Flip C100P Motherboard Replacement: 步骤 8 中的图像 2,2
    • Disconnect the motherboard to powerboard cable from the motherboard using the pointed end of a plastic spudger.
  9. Asus Chromebook Flip C100P Motherboard Replacement: 步骤 9 中的图像 1,2 Asus Chromebook Flip C100P Motherboard Replacement: 步骤 9 中的图像 2,2
    • Disconnect the digitizer board cable from the motherboard using the pointed end of a plastic spudger.
  10. Asus Chromebook Flip C100P Motherboard Replacement: 步骤 10 中的图像 1,1
    • Disconnect the two WiFi antenna cables from the motherboard using the pointed end of a plastic spudger or simply by pulling the cables apart from the motherboard with your fingers.
  11. Asus Chromebook Flip C100P Motherboard Replacement: 步骤 11 中的图像 1,2 Asus Chromebook Flip C100P Motherboard Replacement: 步骤 11 中的图像 2,2
    • Disconnect the speaker cable from the motherboard using the pointed end of a plastic spudger.
  12. Asus Chromebook Flip C100P Motherboard Replacement: 步骤 12 中的图像 1,3 Asus Chromebook Flip C100P Motherboard Replacement: 步骤 12 中的图像 2,3 Asus Chromebook Flip C100P Motherboard Replacement: 步骤 12 中的图像 3,3
    • Remove the four 4.2mm speaker screws, then remove the two speakers using a philips head screwdriver.
  13. Asus Chromebook Flip C100P Motherboard Replacement: 步骤 13 中的图像 1,2 Asus Chromebook Flip C100P Motherboard Replacement: 步骤 13 中的图像 2,2
    • Remove the five 2.7mm motherboard screws with a T5 screwdriver.
  14. Asus Chromebook Flip C100P Motherboard Replacement: 步骤 14 中的图像 1,1
    • Remove the motherboard.
结论
To reassemble your device, replace the broken or faulty motherboard with a new motherboard and follow these instructions in reverse order.
3等其他人完成本指南。
Andrew Acton
于03/19/18注册
469 声望
创作了2篇指南
团队
Baylor, Team S5-G2, Williams Spring 2018 Baylor, Team S5-G2, Williams Spring 2018 的会员
BU-WILLIAMS-S18S5G2
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 2,555
