简介
This guide contains numerous steps and will require an extensive amount of time. You'll need access to a T5 Torx screwdriver to complete this process. Make sure your device is unplugged and turned off to proceed with the guide.
你所需要的
Remove three of the rubber feet on the bottom cover with a plastic or metal spudger.
Remove the nine bottom cover screws using a T5 screwdriver. Set apart the 6mm screw in the rear middle of the bottom cover from the the other eight 3mm screws, as it is longer than them.
Remove the two 2.7mm heat sink screws with a T5 screwdriver, then remove the heat sink from the motherboard.
2等其他人完成本指南。
