跳转到主内容
Asus Chromebook Flip C100P Charging Port Replacement
你所需要的
  1. Asus Chromebook Flip C100P Charging Port Replacement, Charging Port: 步骤 1 中的图像 1,1
    • Remove three of the rubber feet on the bottom cover with a plastic or metal spudger.
  2. Asus Chromebook Flip C100P Charging Port Replacement: 步骤 2 中的图像 1,1
    • Remove the five screws from beneath the rubber feet using a Phillips #0 screwdriver.
    • The first 1.9mm screw is located under the front right foot, the second 1.9mm screw and third 2.3mm screw are located under the rear right foot, and the fourth and fifth 2.3mm screws are located under the rear left foot.
  3. Asus Chromebook Flip C100P Charging Port Replacement: 步骤 3 中的图像 1,1
    • Remove the nine bottom cover screws using a T5 screwdriver.
    • Set apart the 6mm screw in the rear middle of the bottom cover from the the other eight 3mm screws, as it is longer than them.
  4. Asus Chromebook Flip C100P Charging Port Replacement: 步骤 4 中的图像 1,3 Asus Chromebook Flip C100P Charging Port Replacement: 步骤 4 中的图像 2,3 Asus Chromebook Flip C100P Charging Port Replacement: 步骤 4 中的图像 3,3
    • Pry the palm rest assembly apart from the bottom cover using a spudger. This step may require extra power.
    • Once the palm rest has been separated from the bottom cover, pull it away from the screen, rather than away from yourself.
  5. Asus Chromebook Flip C100P Charging Port Replacement: 步骤 5 中的图像 1,3 Asus Chromebook Flip C100P Charging Port Replacement: 步骤 5 中的图像 2,3 Asus Chromebook Flip C100P Charging Port Replacement: 步骤 5 中的图像 3,3
    • Disconnect the touchpad cable and the keyboard cable on the palm rest assembly from the motherboard using the pointed end of a plastic spudger.
  6. Asus Chromebook Flip C100P Charging Port Replacement: 步骤 6 中的图像 1,3 Asus Chromebook Flip C100P Charging Port Replacement: 步骤 6 中的图像 2,3 Asus Chromebook Flip C100P Charging Port Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Disconnect the DC jack cable and the battery cable from the motherboard using tweezers, the pointed end of a plastic spudger, or by simply pulling the cables apart from the motherboard with your fingers.
  7. Asus Chromebook Flip C100P Charging Port Replacement: 步骤 7 中的图像 1,1
    • Remove the two 2.7mm screws using the Phillips #0 screwdriver.
  8. Asus Chromebook Flip C100P Charging Port Replacement: 步骤 8 中的图像 1,1
    • Using a pair of tweezers or your fingers, lift up the charging cable and remove the charging port.
结论
10等其他人完成本指南。
Sid Yadav
于03/19/18注册
424 声望
撰写一个指南
团队
Baylor, Team S5-G2, Williams Spring 2018 Baylor, Team S5-G2, Williams Spring 2018 的会员
BU-WILLIAMS-S18S5G2
3 名成员
创作了8篇指南
一条评论
I just did this but now when I turn it on there is no picture on the computer. I had to change the charging port because my cats knocked over a water glass. The charging port was successful because the light was on. Amy troubleshooting?
Alexandra Miller - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 35
总计 5,784
