跳转到主内容
Asus Chromebook Flip C100P Battery Replacement
你所需要的
  1. Asus Chromebook Flip C100P Battery Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Unscrew the eight bottom cover screws (one of them is under the hand) using a screwdriver with a J1000 tip.
    • Unscrew the middle screw towards the top of the device using a screwdriver with a T5 tip.
  2. Asus Chromebook Flip C100P Battery Replacement: 步骤 2 中的图像 1,1
    • Use the plastic opening tool to remove the four bottom rubber feet.
  3. Asus Chromebook Flip C100P Battery Replacement: 步骤 3 中的图像 1,1
    • Unscrew the four screws under the feet using a screwdriver with a J100 tip.
  4. Asus Chromebook Flip C100P Battery Replacement: 步骤 4 中的图像 1,1
    • Use the plastic opening tool to pry up the palm rest assembly.
  5. Asus Chromebook Flip C100P Battery Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    • Disconnect the two cables from the motherboard with tweezers
  6. Asus Chromebook Flip C100P Battery Replacement, Battery: 步骤 6 中的图像 1,1
    • Unscrew the four J1 Screws of the Audio Cards
  7. Asus Chromebook Flip C100P Battery Replacement: 步骤 7 中的图像 1,1
    • Unscrew the three Battery Screws by using a screwdriver with a J00 tip.
  8. Asus Chromebook Flip C100P Battery Replacement: 步骤 8 中的图像 1,1
    • Lift the battery cable out of Mother Board
结论
To reassemble your device and complete the battery replacement, please follow these instructions in reverse order.
12等其他人完成本指南。
2条评论
The difficulty rating should be higher. The sound card does not need to be removed, but this is not mentioned. I only noticed it from the next picture. Reattaching the keyboard cable is very difficult; a hint with tips would help.
Chas Hofmeister - 回复
I had to searched high and low for this but I'm glad I found this site. Thanks for a great how-to, well done. I wish other sites were a clear and concise.
Eugene Carroll - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 19
总计 11,584
