跳转到主内容
Asus Chromebook Flip C100 Lower Case Replacement
你所需要的
  1. Asus Chromebook Flip C100 Lower Case Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Unscrew the eight bottom cover screws (one of them is under the hand) using a screwdriver with a J1000 tip.
    • Unscrew the middle screw towards the top of the device using a screwdriver with a T5 tip.
  2. Asus Chromebook Flip C100 Lower Case Replacement: 步骤 2 中的图像 1,1
    • Use the plastic opening tool to remove the four bottom rubber feet.
  3. Asus Chromebook Flip C100 Lower Case Replacement: 步骤 3 中的图像 1,1
    • Unscrew the four screws under the feet using a screwdriver with a J100 tip.
  4. Asus Chromebook Flip C100 Lower Case Replacement: 步骤 4 中的图像 1,1
    • Use the plastic opening tool to pry up the palm rest assembly.
  5. Asus Chromebook Flip C100 Lower Case Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Disconnect the two cables from the motherboard with tweezers
结论
11等其他人完成本指南。
一条评论
great guide, though i found the nine screws on the outside required a t5 tip, while the 5 under the feet looked like they were either j100 or j1000, but a philips head worked.
Matthew Sylvester - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 16
总计 5,148
