当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Power the laptop off and make sure the charger is unplugged before starting.
Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
Remove the three 6.0mm Phillips #0 screws.
Open the laptop.
Using an iFixit opening tool, pry along the edges of the keyboard.
Lift the keyboard and slide it gently towards you.
Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
