跳转到主内容
Asus Chromebook C300SA-DS02 VECO Speakers Replacement
你所需要的
  1. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement, Keyboard: 步骤 1 中的图像 1,2 Asus Chromebook C300SA-DS02 VECO Speakers  Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: 步骤 2 中的图像 1,3 Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: 步骤 2 中的图像 2,3 Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: 步骤 2 中的图像 3,3
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: 步骤 3 中的图像 1,3 Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: 步骤 3 中的图像 2,3 Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: 步骤 3 中的图像 3,3
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: 步骤 4 中的图像 1,1
    • Remove the keyboard from the laptop.
  5. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement, Battery: 步骤 5 中的图像 1,2 Asus Chromebook C300SA-DS02 VECO Speakers  Replacement, Battery: 步骤 5 中的图像 2,2
    • Remove the six 5.6mm Phillips #0 screws around the battery.
  6. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: 步骤 6 中的图像 1,2 Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: 步骤 6 中的图像 2,2
    • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
  7. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: 步骤 7 中的图像 1,1
    • Lift the battery out of the laptop.
  8. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement, VECO Speakers: 步骤 8 中的图像 1,1
    • Unplug the speaker cable from the motherboard.
  9. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: 步骤 9 中的图像 1,2 Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: 步骤 9 中的图像 2,2
    • Start by removing the right speaker first.
    • There are two metal clips and one plastic clip holding the right speaker in place. Push them back and lift speaker out of the laptop.
    • Use a screwdriver to gently push back the metal clips.
  10. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: 步骤 10 中的图像 1,2 Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: 步骤 10 中的图像 2,2
    • Untangle the wire connecting the right speaker to the left speaker.
    • Move right speaker and wires away from your working space.
    • Do not lift wire straight up, there are five interlocking ribs holding this wire in place.
  11. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: 步骤 11 中的图像 1,1
    • You can use a screwdriver to push back the clips if needed.
  12. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: 步骤 12 中的图像 1,1
    • Lift speakers and cable away from the laptop.
结论
另外一个人完成了本指南。
Sam LaBelle
于10/17/17注册
107 声望
撰写一个指南
团队
UMass Dartmouth, Team S1-G7, Simcock Fall 2017 UMass Dartmouth, Team S1-G7, Simcock Fall 2017 的会员
UMASSD-SIMCOCK-F17S1G7
3 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 375
