当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Power the laptop off and make sure the charger is unplugged before starting.
Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
Remove the three 6.0mm Phillips #0 screws.
Open the laptop.
Using an iFixit opening tool, pry along the edges of the keyboard.
Lift the keyboard and slide it gently towards you.
Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
Using your Phillips #0 screwdriver, unscrew three, 3.6mm screws from the silver heatsink.
Remove the heatsink from the motherboard.
Remove the black tape from the motherboard covering the 4.2mm silver flat screw.
Using a Phillips #0 screwdriver, remove the 4.4mm screw on the right and the 4.2mm silver flat screw on the left from the motherboard.
This is a used device so the screws may be different than the original Chromebook.
Using the black nylon spudger, unlock the black bar on the ZIF connector attached to the mid-right of the motherboard.
Remove the ribbon cable that attaches the motherboard to the daughterboard.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
