跳转到主内容
Asus Chromebook C300SA-DS02 LED Screen Replacement
你所需要的
  1. Asus Chromebook C300SA-DS02 LED Screen Replacement, Keyboard: 步骤 1 中的图像 1,2 Asus Chromebook C300SA-DS02 LED Screen Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 2 中的图像 1,3 Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 2 中的图像 2,3 Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 2 中的图像 3,3
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 3 中的图像 1,3 Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 3 中的图像 2,3 Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 3 中的图像 3,3
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 4 中的图像 1,1
    • Remove the keyboard from the laptop.
  5. Asus Chromebook C300SA-DS02 LED Screen Replacement, Battery: 步骤 5 中的图像 1,2 Asus Chromebook C300SA-DS02 LED Screen Replacement, Battery: 步骤 5 中的图像 2,2
    • Remove the six 5.6mm Phillips #0 screws around the battery.
  6. Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 6 中的图像 1,2 Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 6 中的图像 2,2
    • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
  7. Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 7 中的图像 1,1
    • Lift the battery out of the laptop.
  8. Asus Chromebook C300SA-DS02 LED Screen Replacement, LED Screen: 步骤 8 中的图像 1,2 Asus Chromebook C300SA-DS02 LED Screen Replacement, LED Screen: 步骤 8 中的图像 2,2
    • Unplug the black and white cable from the motherboard.
    • These two wires connect to the antenna within the display assembly. The white cable is longer and connects to the bottom import.
  9. Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 9 中的图像 1,1
    • Peel back the tape covering the plug.
    • Slide the cable towards the screen and out of the input.
  10. Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 10 中的图像 1,1
    • Unscrew the 6 screws (5 millimeter) on the top right and left.
  11. Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 11 中的图像 1,1
    • Gently lift the screen up and away from the laptop.
  12. Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 12 中的图像 1,1
    • Pry off the face panel on the screen using the blue prying tool.
  13. Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 13 中的图像 1,1
    • Remove the four 2mm Phillips #0 screws from the four corners of the screen.
  14. Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 14 中的图像 1,2 Asus Chromebook C300SA-DS02 LED Screen Replacement: 步骤 14 中的图像 2,2
    • Gently lift screen
    • Peel back the adhesive covering the cable.
    • Remove the cable to free the screen.
结论
另外一个人完成了本指南。
Celina Monteiro
于10/17/17注册
224 声望
创作了2篇指南
团队
UMass Dartmouth, Team S1-G7, Simcock Fall 2017 UMass Dartmouth, Team S1-G7, Simcock Fall 2017 的会员
UMASSD-SIMCOCK-F17S1G7
3 名成员
创作了9篇指南
一条评论
I used this honestly I broke the screen and some of the wires in the screen are severed. Now I know for sure where the wires go and how to deconstruct it. Thank you so much!
Glorybringers Child - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 689
