跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Asus Chromebook C300SA-DS02 Daughterboard Replacement
你所需要的
  1. Asus Chromebook C300SA-DS02 Daughterboard Replacement, Keyboard: 步骤 1 中的图像 1,2 Asus Chromebook C300SA-DS02 Daughterboard Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Asus Chromebook C300SA-DS02 Daughterboard Replacement: 步骤 2 中的图像 1,3 Asus Chromebook C300SA-DS02 Daughterboard Replacement: 步骤 2 中的图像 2,3 Asus Chromebook C300SA-DS02 Daughterboard Replacement: 步骤 2 中的图像 3,3
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Asus Chromebook C300SA-DS02 Daughterboard Replacement: 步骤 3 中的图像 1,3 Asus Chromebook C300SA-DS02 Daughterboard Replacement: 步骤 3 中的图像 2,3 Asus Chromebook C300SA-DS02 Daughterboard Replacement: 步骤 3 中的图像 3,3
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Asus Chromebook C300SA-DS02 Daughterboard Replacement: 步骤 4 中的图像 1,1
    • Remove the keyboard from the laptop.
  5. Asus Chromebook C300SA-DS02 Daughterboard Replacement, Battery: 步骤 5 中的图像 1,2 Asus Chromebook C300SA-DS02 Daughterboard Replacement, Battery: 步骤 5 中的图像 2,2
    • Remove the six 5.6mm Phillips #0 screws around the battery.
  6. Asus Chromebook C300SA-DS02 Daughterboard Replacement: 步骤 6 中的图像 1,2 Asus Chromebook C300SA-DS02 Daughterboard Replacement: 步骤 6 中的图像 2,2
    • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
  7. Asus Chromebook C300SA-DS02 Daughterboard Replacement: 步骤 7 中的图像 1,1
    • Lift the battery out of the laptop.
  8. Asus Chromebook C300SA-DS02 Daughterboard Replacement, Display Assembly: 步骤 8 中的图像 1,2 Asus Chromebook C300SA-DS02 Daughterboard Replacement, Display Assembly: 步骤 8 中的图像 2,2
    • Unplug the black and white cable from the motherboard.
    • These two wires connect to the antenna within the display assembly. The white cable is longer and connects to the bottom import.
  9. Asus Chromebook C300SA-DS02 Daughterboard Replacement: 步骤 9 中的图像 1,1
    • Peel back the tape covering the display cable.
    • Ease the cable towards the screen and out from the connector.
  10. Asus Chromebook C300SA-DS02 Daughterboard Replacement: 步骤 10 中的图像 1,1
    • Use a Phillips #0 driver to remove the six 5mm screws on the top right and left display hinges.
  11. Asus Chromebook C300SA-DS02 Daughterboard Replacement: 步骤 11 中的图像 1,1
    • Gently lift the display assembly up and away from the laptop.
  12. Asus Chromebook C300SA-DS02 Daughterboard Replacement, Daughterboard: 步骤 12 中的图像 1,3 Asus Chromebook C300SA-DS02 Daughterboard Replacement, Daughterboard: 步骤 12 中的图像 2,3 Asus Chromebook C300SA-DS02 Daughterboard Replacement, Daughterboard: 步骤 12 中的图像 3,3
    • Using your Phillips #0 screwdriver, unscrew three, 3.6mm screws from the silver heat sink.
    • Remove the heat sink from the motherboard.
  13. Asus Chromebook C300SA-DS02 Daughterboard Replacement: 步骤 13 中的图像 1,3 Asus Chromebook C300SA-DS02 Daughterboard Replacement: 步骤 13 中的图像 2,3 Asus Chromebook C300SA-DS02 Daughterboard Replacement: 步骤 13 中的图像 3,3
    • Use a spudger to flip up the locking tab on the ZIF connector of the daughterboard.
    • Slide the ribbon cable from the connector.
  14. Asus Chromebook C300SA-DS02 Daughterboard Replacement: 步骤 14 中的图像 1,1
    • Remove the daughterboard by lifting it from the bottom case.
结论
Austin Blakely
于03/11/19注册
19,506 声望
创作了53篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 223
