简介
This guide will demonstrate how to safely remove the battery from your Asus Chromebook C300SA-DS02. This step by step process is simple and should take no longer then five minutes. All of the screws holding the device together are documented by the correct type during the correct step. Make sure to keep track of them throughout the guide.
你所需要的
Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
Remove the three 6.0mm Phillips #0 screws.
另外一个人完成了本指南。
