你所需要的
Flip the Chromebook onto its back, where there are eleven screws.
There are two variations of screws on the back panel:
Six 8.7mm screws.
Five 6.4mm screws.
Using your screwdriver with the J00 Phillips Head tip, remove the screws by turning them counter clockwise.
Once the keyboard is removed, the battery is located on the bottom portion of the shell.
The battery is held in with six 6.5mm screws on opposing sides.
The metal plate is held in by two 3.4mm Phillip head screws.
Remove them by turning the screws counter clockwise.
Lift the plate off using a plastic opening tool or by hand.
