跳转到主内容
Asus Chromebook C300MA-EDU Keyboard Replacement
你所需要的
  1. Asus Chromebook C300MA-EDU Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,2 Asus Chromebook C300MA-EDU Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Flip the Chromebook onto its back, where there are eleven screws.
    • There are two variations of screws on the back panel:
    • Six 8.7mm screws.
    • Five 6.4mm screws.
    • Using your screwdriver with the J00 Phillips Head tip, remove the screws by turning them counter clockwise.
  2. Asus Chromebook C300MA-EDU Keyboard Replacement: 步骤 2 中的图像 1,2 Asus Chromebook C300MA-EDU Keyboard Replacement: 步骤 2 中的图像 2,2
    • Once the screws are removed, flip the Chromebook back over.
    • Gently remove the keyboard by starting to lift up on one corner with a plastic opening tool.
    • Follow around the brim of the keyboard until it pops off.
  3. Asus Chromebook C300MA-EDU Keyboard Replacement: 步骤 3 中的图像 1,3 Asus Chromebook C300MA-EDU Keyboard Replacement: 步骤 3 中的图像 2,3 Asus Chromebook C300MA-EDU Keyboard Replacement: 步骤 3 中的图像 3,3
    • Once you remove the keyboard, it will be connected to the CPU with two tabbed connections.
    • Release the connections from the tabs gently by flipping the white flaps up until disconnected.
    • You can now pull the ribbons out from the board and remove the keyboard.
结论
Christopher Hart
于09/28/17注册
501 声望
创作了5篇指南
团队
USF Tampa, Team S2-G3, Nance Fall 2017 USF Tampa, Team S2-G3, Nance Fall 2017 的会员
USFT-NANCE-F17S2G3
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 692
