跳转到主内容
Asus Chromebook C300MA-DH02 Trackpad Replacement
你所需要的
  1. Asus Chromebook C300MA-DH02 Trackpad Replacement, Keyboard Panel: 步骤 1 中的图像 1,3 Asus Chromebook C300MA-DH02 Trackpad Replacement, Keyboard Panel: 步骤 1 中的图像 2,3 Asus Chromebook C300MA-DH02 Trackpad Replacement, Keyboard Panel: 步骤 1 中的图像 3,3
    • Flip the Chromebook over so that the underside is facing up.
    • Using the Phillips PH #000 screwdriver, remove the 11 "4mm" screws on the back of the device.
  2. Asus Chromebook C300MA-DH02 Trackpad Replacement: 步骤 2 中的图像 1,1
    • Wedge the plastic opening tool between the bottom cover of the laptop and the keyboard panel.
    • Apply pressure and move the plastic opening tool around the border of the laptop until it pops out.
  3. Asus Chromebook C300MA-DH02 Trackpad Replacement: 步骤 3 中的图像 1,2 Asus Chromebook C300MA-DH02 Trackpad Replacement: 步骤 3 中的图像 2,2
    • Once the keyboard panel pops out, slowly move it upwards so that the keyboard connection is visible.
    • Remove the keyboard connection from the motherboard by pulling it outwards from the connector.
  4. Asus Chromebook C300MA-DH02 Trackpad Replacement, Trackpad: 步骤 4 中的图像 1,2 Asus Chromebook C300MA-DH02 Trackpad Replacement, Trackpad: 步骤 4 中的图像 2,2
    • Unplug the blue wire that connects trackpad to the keyboard.
  5. Asus Chromebook C300MA-DH02 Trackpad Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    • Remove the aluminum tape that secures the trackpad. Use tweezers if necessary.
  6. Asus Chromebook C300MA-DH02 Trackpad Replacement: 步骤 6 中的图像 1,2 Asus Chromebook C300MA-DH02 Trackpad Replacement: 步骤 6 中的图像 2,2
    • Using the Phillips #000 screwdriver, remove the (4) four "4 mm" screws that secure trackpad onto keyboard.
  7. Asus Chromebook C300MA-DH02 Trackpad Replacement: 步骤 7 中的图像 1,2 Asus Chromebook C300MA-DH02 Trackpad Replacement: 步骤 7 中的图像 2,2
    • Using a plastic opening tool, pry out the touchpad from the metal securing bracket.
结论
2等其他人完成本指南。
Raaefazer
于10/02/17注册
131 声望
撰写一个指南
团队
USF Tampa, Team S6-G4, Remmell Fall 2017 USF Tampa, Team S6-G4, Remmell Fall 2017 的会员
USFT-REMMELL-F17S6G4
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 240
