跳转到主内容
Asus Chromebook C300MA-DH02 Motherboard Replacement
你所需要的
  1. Asus Chromebook C300MA-DH02 Motherboard Replacement, Keyboard Panel: 步骤 1 中的图像 1,3 Asus Chromebook C300MA-DH02 Motherboard Replacement, Keyboard Panel: 步骤 1 中的图像 2,3 Asus Chromebook C300MA-DH02 Motherboard Replacement, Keyboard Panel: 步骤 1 中的图像 3,3
    • Flip the Chromebook over so that the underside is facing up.
    • Using the Phillips PH #000 screwdriver, remove the 11 "4mm" screws on the back of the device.
  2. Asus Chromebook C300MA-DH02 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Wedge the plastic opening tool between the bottom cover of the laptop and the keyboard panel.
    • Apply pressure and move the plastic opening tool around the border of the laptop until it pops out.
  3. Asus Chromebook C300MA-DH02 Motherboard Replacement: 步骤 3 中的图像 1,2 Asus Chromebook C300MA-DH02 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Once the keyboard panel pops out, slowly move it upwards so that the keyboard connection is visible.
    • Remove the keyboard connection from the motherboard by pulling it outwards from the connector.
  4. Asus Chromebook C300MA-DH02 Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,2 Asus Chromebook C300MA-DH02 Motherboard Replacement, Motherboard: 步骤 4 中的图像 2,2
    • Remove the 4 "4mm" screws on the silver motherboard cover with the Phillips #000 Screwdriver.
    • Remove the motherboard silver mount.
  5. Asus Chromebook C300MA-DH02 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Use a plastic opening tool to remove the connection from sound driver on the bottom left of the motherboard.
  6. Asus Chromebook C300MA-DH02 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Gently remove the blue connector to the right side of the motherboard.
  7. Asus Chromebook C300MA-DH02 Motherboard Replacement: 步骤 7 中的图像 1,2 Asus Chromebook C300MA-DH02 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Use the Phillips #000 Screwdriver to remove the screw on right side of wireless card.
    • Remove the wireless card.
  8. Asus Chromebook C300MA-DH02 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Start by lifting tape up off of the connection. Remove the connection to display.
  9. Asus Chromebook C300MA-DH02 Motherboard Replacement: 步骤 9 中的图像 1,3 Asus Chromebook C300MA-DH02 Motherboard Replacement: 步骤 9 中的图像 2,3 Asus Chromebook C300MA-DH02 Motherboard Replacement: 步骤 9 中的图像 3,3
    • Remove (3) three "4mm" screws that connect the hinge to the motherboard using the Phillips #000 Screwdriver.
    • Remove (5) five "4mm" screws around two sides of motherboard using the Phillips #000 Screwdriver.
  10. Asus Chromebook C300MA-DH02 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Gently remove motherboard from the Asus Chromebook.
结论
2等其他人完成本指南。
团队
USF Tampa, Team S6-G4, Remmell Fall 2017 USF Tampa, Team S6-G4, Remmell Fall 2017 的会员
USFT-REMMELL-F17S6G4
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 292
