跳转到主内容
Asus Chromebook C300MA-DH02 Display Replacement
你所需要的
  1. Asus Chromebook C300MA-DH02 Display Replacement, Keyboard Panel: 步骤 1 中的图像 1,3 Asus Chromebook C300MA-DH02 Display Replacement, Keyboard Panel: 步骤 1 中的图像 2,3 Asus Chromebook C300MA-DH02 Display Replacement, Keyboard Panel: 步骤 1 中的图像 3,3
    • Flip the Chromebook over so that the underside is facing up.
    • Using the Phillips PH #000 screwdriver, remove the 11 "4mm" screws on the back of the device.
  2. Asus Chromebook C300MA-DH02 Display Replacement: 步骤 2 中的图像 1,1
    • Wedge the plastic opening tool between the bottom cover of the laptop and the keyboard panel.
    • Apply pressure and move the plastic opening tool around the border of the laptop until it pops out.
  3. Asus Chromebook C300MA-DH02 Display Replacement: 步骤 3 中的图像 1,2 Asus Chromebook C300MA-DH02 Display Replacement: 步骤 3 中的图像 2,2
    • Once the keyboard panel pops out, slowly move it upwards so that the keyboard connection is visible.
    • Remove the keyboard connection from the motherboard by pulling it outwards from the connector.
  4. Asus Chromebook C300MA-DH02 Display Replacement, Display: 步骤 4 中的图像 1,2 Asus Chromebook C300MA-DH02 Display Replacement, Display: 步骤 4 中的图像 2,2
    • Remove the hinge protector by using the plastic opening tool to gently lift it up. It should come up easily.
  5. Asus Chromebook C300MA-DH02 Display Replacement: 步骤 5 中的图像 1,2 Asus Chromebook C300MA-DH02 Display Replacement: 步骤 5 中的图像 2,2
    • Using the plastic opening tool, separate the display cover bracket from the back of the display. Start from the top.
  6. Asus Chromebook C300MA-DH02 Display Replacement: 步骤 6 中的图像 1,2 Asus Chromebook C300MA-DH02 Display Replacement: 步骤 6 中的图像 2,2
    • Remove the (4) four "4mm" screws in each corner that hold the display using the Phillips #000 screwdriver.
  7. Asus Chromebook C300MA-DH02 Display Replacement: 步骤 7 中的图像 1,1
    • Lower the display to allow access to connector in back.
  8. Asus Chromebook C300MA-DH02 Display Replacement: 步骤 8 中的图像 1,2 Asus Chromebook C300MA-DH02 Display Replacement: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    • Lift the tape covering the connector with the tweezers.
    • Gently remove the display connector from the motherboard.
结论
Zachary Leonard
于10/02/17注册
304 声望
创作了3篇指南
团队
USF Tampa, Team S6-G4, Remmell Fall 2017 USF Tampa, Team S6-G4, Remmell Fall 2017 的会员
USFT-REMMELL-F17S6G4
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 246
