跳转到主内容
Asus Chromebook C300MA-DH02 Battery Replacement
你所需要的
  1. Asus Chromebook C300MA-DH02 Battery Replacement, Keyboard Panel: 步骤 1 中的图像 1,3 Asus Chromebook C300MA-DH02 Battery Replacement, Keyboard Panel: 步骤 1 中的图像 2,3 Asus Chromebook C300MA-DH02 Battery Replacement, Keyboard Panel: 步骤 1 中的图像 3,3
    • Flip the Chromebook over so that the underside is facing up.
    • Using the Phillips PH #000 screwdriver, remove the 11 "4mm" screws on the back of the device.
  2. Asus Chromebook C300MA-DH02 Battery Replacement: 步骤 2 中的图像 1,1
    • Wedge the plastic opening tool between the bottom cover of the laptop and the keyboard panel.
    • Apply pressure and move the plastic opening tool around the border of the laptop until it pops out.
  3. Asus Chromebook C300MA-DH02 Battery Replacement: 步骤 3 中的图像 1,2 Asus Chromebook C300MA-DH02 Battery Replacement: 步骤 3 中的图像 2,2
    • Once the keyboard panel pops out, slowly move it upwards so that the keyboard connection is visible.
    • Remove the keyboard connection from the motherboard by pulling it outwards from the connector.
  4. Asus Chromebook C300MA-DH02 Battery Replacement, Battery: 步骤 4 中的图像 1,2 Asus Chromebook C300MA-DH02 Battery Replacement, Battery: 步骤 4 中的图像 2,2
    • Remove (6) six "4mm" screws that hold the battery using the Phillips #000 screwdriver.
  5. Asus Chromebook C300MA-DH02 Battery Replacement: 步骤 5 中的图像 1,1
    • Placing two plastic opening tools on each side of the battery connector and gently pull with an even force on both sides of the connector until the connector pops out.
  6. Asus Chromebook C300MA-DH02 Battery Replacement: 步骤 6 中的图像 1,1
    • Note: Your battery may have adhesive on the underside. If you cannot easily remove the battery you can use a hair dryer to evenly warm the glue.
    • Remove the battery by applying even force on both sides.
    • During reassembly, purchase of adhesive may be necessary.
结论
另外一个人完成了本指南。
Zachary Leonard
于10/02/17注册
304 声望
创作了3篇指南
团队
USF Tampa, Team S6-G4, Remmell Fall 2017 USF Tampa, Team S6-G4, Remmell Fall 2017 的会员
USFT-REMMELL-F17S6G4
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 250
