跳转到主内容
Asus Chromebook C300MA-DB01 Screen Replacement
你所需要的
  1. Asus Chromebook C300MA-DB01 Screen Replacement, Screen: 步骤 1 中的图像 1,2 Asus Chromebook C300MA-DB01 Screen Replacement, Screen: 步骤 1 中的图像 2,2
    • Use plastic opening tool to remove the frame around the screen. It is recommended to start in the upper corners.
  2. Asus Chromebook C300MA-DB01 Screen Replacement: 步骤 2 中的图像 1,2 Asus Chromebook C300MA-DB01 Screen Replacement: 步骤 2 中的图像 2,2
    • Use plastic opening tool to remove plastic hinge casing located between the screen and keyboard.
  3. Asus Chromebook C300MA-DB01 Screen Replacement: 步骤 3 中的图像 1,1
    • Use 64 bitdriver to remove 4 6.0 mm Phillips screws from screen the screws that need to be removed are located in the corners of the screen.
  4. Asus Chromebook C300MA-DB01 Screen Replacement: 步骤 4 中的图像 1,1
    • Use plastic prying tool to detach the wire that connects the screen to the lower non-display half of the laptop.
  5. Asus Chromebook C300MA-DB01 Screen Replacement: 步骤 5 中的图像 1,1
    • Lift and remove screen from the laptop.
结论
wyatt boyatt
于09/25/17注册
541 声望
创作了5篇指南
团队
USF Tampa, Team S4-G3, Eyestone Fall 2017 USF Tampa, Team S4-G3, Eyestone Fall 2017 的会员
USFT-EYESTONE-F17S4G3
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 334
