跳转到主内容
Asus Chromebook C300MA-DB01 Keyboard Replacement
你所需要的
  1. Asus Chromebook C300MA-DB01 Keyboard Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Place device bottom-side up.
  2. Asus Chromebook C300MA-DB01 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Remove the three 6.0 mm Philips screws from the center of the case with the #2 screwdriver bit.
    • Remove the eight 9.0 mm Philips screws along the perimeter of the case with the #2 screwdriver bit.
  3. Asus Chromebook C300MA-DB01 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Using a plastic opening tool, separate the bottom case at the seam.
    • Prying open a laptop requires a lot of force but use caution so as to avoid breaking the fragile connectors.
  4. Asus Chromebook C300MA-DB01 Keyboard Replacement: 步骤 4 中的图像 1,2 Asus Chromebook C300MA-DB01 Keyboard Replacement: 步骤 4 中的图像 2,2
    • Lift the keyboard panel away from the components at its hinges, which are located at the back of the laptop.
  5. Asus Chromebook C300MA-DB01 Keyboard Replacement, Keyboard: 步骤 5 中的图像 1,1
    • Use plastic opening tool to pry open clip holding keyboard wires to the circuitboard.
  6. Asus Chromebook C300MA-DB01 Keyboard Replacement: 步骤 6 中的图像 1,1
    • Use plastic opening tool to pry open clip holding mouse pad wires to the circuit board.
    • Use plastic opening tool to pry open clip holding keyboard flat black wire
    • Use plastic opening tool to pry open clip holding keyboard thiner white wire
  7. Asus Chromebook C300MA-DB01 Keyboard Replacement: 步骤 7 中的图像 1,1
    • Lift and remove keyboard from device.
结论
wyatt boyatt
于09/25/17注册
541 声望
创作了5篇指南
团队
USF Tampa, Team S4-G3, Eyestone Fall 2017 USF Tampa, Team S4-G3, Eyestone Fall 2017 的会员
USFT-EYESTONE-F17S4G3
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 319
