跳转到主内容
Asus Chromebook C300MA-BBCLN12 Keyboard Replacement
你所需要的
  1. Asus Chromebook C300MA-BBCLN12 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,3 Asus Chromebook C300MA-BBCLN12 Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,3 Asus Chromebook C300MA-BBCLN12 Keyboard Replacement, Keyboard: 步骤 1 中的图像 3,3
    • Remove the eight 9.0mm PH00 Phillips screws along the perimeter of the bottom housing.
    • Remove the three 6.0mm PH00 Phillips screws from the center of the bottom housing.
  2. Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: 步骤 2 中的图像 1,3 Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: 步骤 2 中的图像 2,3 Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: 步骤 2 中的图像 3,3
    • Separate the palm rest assembly from the bottom housing using the plastic opening tool.
    • It is recommended that you start from a corner and run the tip of the plastic opening tool along the edge of the housing.
    • Lift the palm rest assembly slowly to prevent damaging the two cables connecting it to the motherboard.
  3. Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: 步骤 3 中的图像 1,3 Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: 步骤 3 中的图像 2,3 Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Flip back the hinges on the connectors that secure the wide black cable and the narrow white cable using the tweezers.
    • Disconnect the wide black cable from the motherboard by pulling the blue cable tab straight out of the connector.
    • Disconnect the white ribbon cable from the motherboard by pulling the blue cable tab straight out of the connector.
  4. Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: 步骤 4 中的图像 1,3 Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: 步骤 4 中的图像 2,3 Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: 步骤 4 中的图像 3,3
    • Flip back the hinge on the connector that secures the white ribbon cable to the underside of the palm rest assembly using the tweezers.
    • Disconnect the white ribbon cable from the palm rest assembly by pulling the cable straight out of the connector.
  5. Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: 步骤 5 中的图像 1,3 Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: 步骤 5 中的图像 2,3 Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: 步骤 5 中的图像 3,3
    • Remove the palm rest assembly from the bottom housing and lay it on a flat surface with the keyboard facing downward.
    • Remove the four 5.0mm PH00 Phillips screws securing the keyboard to the palm rest assembly.
    • Separate the keyboard from the palm rest assembly.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 409
