跳转到主内容
Asus Chromebook C300MA-BBCLN12 Display Replacement
你所需要的
  1. Asus Chromebook C300MA-BBCLN12 Display Replacement, Display: 步骤 1 中的图像 1,3 Asus Chromebook C300MA-BBCLN12 Display Replacement, Display: 步骤 1 中的图像 2,3 Asus Chromebook C300MA-BBCLN12 Display Replacement, Display: 步骤 1 中的图像 3,3
    • Wedge the tip of the plastic spudger between the outer display casing and the inner display panel liner.
    • Separate the outer display casing from the inner display panel by sliding the plastic spudger around the perimeter of the display.
    • It is necessary to pull the inner display panel firmly when separating it from the outer display casing along the bottom of the device.
  2. Asus Chromebook C300MA-BBCLN12 Display Replacement: 步骤 2 中的图像 1,3 Asus Chromebook C300MA-BBCLN12 Display Replacement: 步骤 2 中的图像 2,3 Asus Chromebook C300MA-BBCLN12 Display Replacement: 步骤 2 中的图像 3,3
    • Remove the four 3.0mm PH00 screws from the four corners of the display.
    • Grip the edges of the display and tip it forward until it rests on the keyboard.
    • A cable connects the display to the display casing at the bottom. Separate the display panel slowly to prevent damaging the cable.
  3. Asus Chromebook C300MA-BBCLN12 Display Replacement: 步骤 3 中的图像 1,3 Asus Chromebook C300MA-BBCLN12 Display Replacement: 步骤 3 中的图像 2,3 Asus Chromebook C300MA-BBCLN12 Display Replacement: 步骤 3 中的图像 3,3
    • Locate the gold cable connector that attaches the display to the bottom of the display housing.
    • Peel back the protective tape that covers the gold connector.
    • Disconnect the display from the display housing by gripping the sides of the gold display cable connector and pulling away from the bottom of the display.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 226
