跳转到主内容
Asus Chromebook C300MA DB01 Screen Replacement
你所需要的
  1. Asus Chromebook C300MA DB01 Screen Replacement, Screen: 步骤 1 中的图像 1,3 Asus Chromebook C300MA DB01 Screen Replacement, Screen: 步骤 1 中的图像 2,3 Asus Chromebook C300MA DB01 Screen Replacement, Screen: 步骤 1 中的图像 3,3
    • Use a Jimmy to pry off the hinge cover from the screen.
  2. Asus Chromebook C300MA DB01 Screen Replacement: 步骤 2 中的图像 1,2 Asus Chromebook C300MA DB01 Screen Replacement: 步骤 2 中的图像 2,2
    • Run the Jimmy along the edges of the screen frame to unsnap it from the connectors.
    • Remove the screen frame manually.
  3. Asus Chromebook C300MA DB01 Screen Replacement: 步骤 3 中的图像 1,3 Asus Chromebook C300MA DB01 Screen Replacement: 步骤 3 中的图像 2,3 Asus Chromebook C300MA DB01 Screen Replacement: 步骤 3 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the four screws on each corner of the screen.
    • Separate the screen from the top of the Chromebook with the Jimmy.
    • Avoid pulling the screen too far from the device as this can disconnect the wire located at the bottom of the screen.
    • Use the Jimmy to lift the latch on the wire jack.
    • Remove the wires and detach the screen from the device manually.
结论
Earl Gill IV
于04/01/19注册
193 声望
创作了2篇指南
团队
IUPUI, Team S10-G10, Wilson Spring 2019 IUPUI, Team S10-G10, Wilson Spring 2019 的会员
IUPUI-WILSON-S19S10G10
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 127
