跳转到主内容
Asus Chromebook C300MA DB01 Battery Replacement
你所需要的
  1. Asus Chromebook C300MA DB01 Battery Replacement, Removing the Back Cover: 步骤 1 中的图像 1,1
    • Remove the eight 9.0 mm Phillips screws along the perimeter of the case.
    • Remove the three 6.0 mm Phillips screws from the center of the case.
  2. Asus Chromebook C300MA DB01 Battery Replacement, Taking off the Keyboard: 步骤 2 中的图像 1,2 Asus Chromebook C300MA DB01 Battery Replacement, Taking off the Keyboard: 步骤 2 中的图像 2,2
    • Slide the Jimmy in between the keyboard and underside of the laptop to remove the keyboard.
    • Leave the keyboard face down on the screen.
    • Do not pull the keyboard away from the laptop. The keyboard will still be attached with wires.
  3. Asus Chromebook C300MA DB01 Battery Replacement, Detaching keyboard: 步骤 3 中的图像 1,2 Asus Chromebook C300MA DB01 Battery Replacement, Detaching keyboard: 步骤 3 中的图像 2,2
    • Use a nylon spudger to lift the latch on each wire jack and detach the keyboard wires.
    • After the tabs have been lifted, the wire can be gently pulled out by hand.
    • Set the keyboard aside.
  4. Asus Chromebook C300MA DB01 Battery Replacement, Removing the battery: 步骤 4 中的图像 1,3 Asus Chromebook C300MA DB01 Battery Replacement, Removing the battery: 步骤 4 中的图像 2,3 Asus Chromebook C300MA DB01 Battery Replacement, Removing the battery: 步骤 4 中的图像 3,3
    • Remove the six 6.0mm Phillips screws on the battery.
    • Remove the wire jack from the battery. Use a nylon spudger to lift the latch.
    • Remove the battery from the device.
结论
Earl Gill IV
于04/01/19注册
193 声望
创作了2篇指南
团队
IUPUI, Team S10-G10, Wilson Spring 2019 IUPUI, Team S10-G10, Wilson Spring 2019 的会员
IUPUI-WILSON-S19S10G10
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 214
