简介
This repair guide will give step-by-step instructions on how to remove the back of the Chromebook to remove and replace the USB Port.
你所需要的
Flip the chromebook on its front.
Remove the screws on the back using the Phillips #1 screwdriver.
Remove the six 8mm screws.
Remove the five 5mm screws.
Remove the single 3mm screw on the left and bottom side of the USB Port using the Phillips #1 screwdriver.
Remove the three 5mm screws on the upper part of the USB port with the same screwdriver.
Lift the edge of the white casing. Remove the USB Port by pulling it toward the bottom of the laptop.
2等其他人完成本指南。
