跳转到主内容
Asus Chromebook C300M Screen Replacement
你所需要的
  1. Asus Chromebook C300M Screen Replacement, Bottom Panel: 步骤 1 中的图像 1,1
    • Flip the Chromebook over, bottom-side up.
  2. Asus Chromebook C300M Screen Replacement: 步骤 2 中的图像 1,2 Asus Chromebook C300M Screen Replacement: 步骤 2 中的图像 2,2
    • Remove the screws from the 11 spots using the aluminum driver with the J00 Philips head provided in iFixit toolkit.
    • Remove the eight 9.0mm Philips screws along the perimeter of the case.
    • Remove the three 6.0mm Philips screws from the center of the case.
    • Some versions may instead have six bigger screws (the four on the upper side of the image, close to the hinge, and two on the sides) and five smaller ones (four at the bottom of the image, where the laptop is thinner, and one in the center).
  3. Asus Chromebook C300M Screen Replacement: 步骤 3 中的图像 1,1
    • Using a plastic opening tool, work around the Chromebook separating the plastic case at the seam.
  4. Asus Chromebook C300M Screen Replacement: 步骤 4 中的图像 1,1
    • Open the Chromebook at hinges.
  5. Asus Chromebook C300M Screen Replacement, Screen: 步骤 5 中的图像 1,1
    • Wedge the tip of a plastic opening tool between the outer casing and inner screen liner.
    • Use the tool to pry all the way around the case, including the bottom side near the hinge, until the case is completely separated.
  6. Asus Chromebook C300M Screen Replacement: 步骤 6 中的图像 1,1
    • Pop the inner screen liner using your fingers, gently, until completely separated from the screen.
  7. Asus Chromebook C300M Screen Replacement: 步骤 7 中的图像 1,1
    • Completely remove the inner screen liner and set aside.
  8. Asus Chromebook C300M Screen Replacement: 步骤 8 中的图像 1,2 Asus Chromebook C300M Screen Replacement: 步骤 8 中的图像 2,2
    • Use the aluminum driver and the J00 head to remove screws surrounding the screen.
    • Remove the four 2.0mm screws from the four corners
    • Remove the four 3.0mm screws from the bottom hinge.
  9. Asus Chromebook C300M Screen Replacement: 步骤 9 中的图像 1,1
    • Grip the edges of the screen and gently lay down onto of the keys.
    • Bottom of the screen is still connected on the backside of the screen.
  10. Asus Chromebook C300M Screen Replacement: 步骤 10 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Take the metal angled tweezers to detach the connector from the back of the screen.
  11. Asus Chromebook C300M Screen Replacement: 步骤 11 中的图像 1,1
    • Grip the screen gently and remove it from the rest of the Chromebook.
    • Chromebook is now ready for the new screen to be attached!
结论
9等其他人完成本指南。
Jake Van Loon
于09/25/15注册
995 声望
创作了3篇指南
团队
3条评论
I’m having some real trouble getting the inner screen liner back on. I can’t seem to get it to hook under the plastic around the hinge mechanism. If you have completed this repair and could offer any advice on this aspect of it I would greatly appreciate it. Thanks!
Nathan Massey - 回复
I found the answer on YouTube (https://www.youtube.com/watch?v=fWYr8CfZ...). Turns out there is a much easier method to replace the screen the doesn’t require unscrewing the bottom of the Chromebook at all. You just remove the hinge cover and screen liner, swap out the screen then replace the screen liner and hinge cover.
Nathan Massey -
I used this guide to fix the cable running to the screen. Turns out Asus had installed the cable over the hinge and not under as with the antennae.
deathdisco - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 24
总计 8,282
