跳转到主内容
Asus Chromebook C300M Key Replacement
你所需要的
  1. Asus Chromebook C300M Key Replacement, Bottom Panel: 步骤 1 中的图像 1,1
    • Flip the Chromebook over, bottom-side up.
  2. Asus Chromebook C300M Key Replacement: 步骤 2 中的图像 1,2 Asus Chromebook C300M Key Replacement: 步骤 2 中的图像 2,2
    • Remove the screws from the 11 spots using the aluminum driver with the J00 Philips head provided in iFixit toolkit.
    • Remove the eight 9.0mm Philips screws along the perimeter of the case.
    • Remove the three 6.0mm Philips screws from the center of the case.
    • Some versions may instead have six bigger screws (the four on the upper side of the image, close to the hinge, and two on the sides) and five smaller ones (four at the bottom of the image, where the laptop is thinner, and one in the center).
  3. Asus Chromebook C300M Key Replacement: 步骤 3 中的图像 1,1
    • Using a plastic opening tool, work around the Chromebook separating the plastic case at the seam.
  4. Asus Chromebook C300M Key Replacement: 步骤 4 中的图像 1,1
    • Open the Chromebook at hinges.
  5. Asus Chromebook C300M Key Replacement, Key: 步骤 5 中的图像 1,1
    • Detach the wide black keyboard cable from the switchboard.
  6. Asus Chromebook C300M Key Replacement: 步骤 6 中的图像 1,1
    • Unplug the white keyboard cable from switchboard.
  7. Asus Chromebook C300M Key Replacement: 步骤 7 中的图像 1,1
    • Remove the keyboard from the laptop body.
  8. Asus Chromebook C300M Key Replacement: 步骤 8 中的图像 1,1
    • Use the plastic opening tool to loosen a key of choice.
  9. Asus Chromebook C300M Key Replacement: 步骤 9 中的图像 1,1
    在这个步骤中使用的工具:
    • Removed the loosened key with the tweezers.
结论
6等其他人完成本指南。
Jake Van Loon
于09/25/15注册
1,010 声望
创作了3篇指南
团队
1指南评论
hello, i have a asus c300 my problem is when i open it i have get it just right to see picture .is it my video cable?
clint murchison - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 27
总计 5,204
