跳转到主内容
Asus Chromebook C202SA-YS02 Touch Pad Replacement
你所需要的
  1. Asus Chromebook C202SA-YS02 Touch Pad Replacement, Palm Rest: 步骤 1 中的图像 1,1
    • Turn the device over so the bottom is facing up.
    • Remove the ten Phillips #1 8.0 mm screws.
  2. Asus Chromebook C202SA-YS02 Touch Pad Replacement: 步骤 2 中的图像 1,2 Asus Chromebook C202SA-YS02 Touch Pad Replacement: 步骤 2 中的图像 2,2
    • Carefully use the plastic opening tool to pry the palm rest apart from the bottom cover. Start from one spot and systematically work your way around until the whole palm rest is detached.
  3. Asus Chromebook C202SA-YS02 Touch Pad Replacement: 步骤 3 中的图像 1,1
    • Disconnect the two cables that run from the keyboard to the motherboard and from the touch pad to the motherboard.
    • You may have to use a spudger to lift open the respective latches.
  4. Asus Chromebook C202SA-YS02 Touch Pad Replacement, Touch Pad: 步骤 4 中的图像 1,1
    • Gently peel off gold tape.
  5. Asus Chromebook C202SA-YS02 Touch Pad Replacement: 步骤 5 中的图像 1,1
    • Remove the three Phillips #1 3.5 mm screws located on the under-side of the palm rest.
    • You can now pop out the touch pad.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 30
总计 1,486
