跳转到主内容
Asus Chromebook C202SA-YS02 Screen Replacement
你所需要的
  1. Asus Chromebook C202SA-YS02 Screen Replacement, Bezel: 步骤 1 中的图像 1,1
    • Using a flat blade, remove the two screw covers on the front of the bezel. They are attached by adhesive, so you may have to dig at it a little bit.
  2. Asus Chromebook C202SA-YS02 Screen Replacement: 步骤 2 中的图像 1,1
    • Unscrew and remove the two Phillips #1 4.5 mm screws that are now visible.
  3. Asus Chromebook C202SA-YS02 Screen Replacement: 步骤 3 中的图像 1,1
    • Using the plastic opening tool, carefully pry off the bezel. It will come off entirely, so be careful not to break it.
  4. Asus Chromebook C202SA-YS02 Screen Replacement, Screen: 步骤 4 中的图像 1,3 Asus Chromebook C202SA-YS02 Screen Replacement, Screen: 步骤 4 中的图像 2,3 Asus Chromebook C202SA-YS02 Screen Replacement, Screen: 步骤 4 中的图像 3,3
    • Unscrew and remove the four screws holding the screen in place.
  5. Asus Chromebook C202SA-YS02 Screen Replacement: 步骤 5 中的图像 1,1
    • Fold down screen and remove the screen connector band. You may have to use a small flat blade or a spudger, since the latch is very small.
结论
4等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 35
总计 3,610
