简介
The daughterboard is an extension of the motherboard. The daughterboard is connected to the USB drive, so when you plug into the USB compartment, the daughterboard communicates with the motherboard. This guide will show how to remove the daughterboard/USB piece.
你所需要的
Turn the device over so the bottom is facing up.
Remove the ten Phillips #1 8.0 mm screws.
即将完成!
结论
