跳转到主内容
Asus Chromebook C202SA-YS02 Camera Replacement
你所需要的
  1. Asus Chromebook C202SA-YS02 Camera Replacement, Bezel: 步骤 1 中的图像 1,1
    • Using a flat blade, remove the two screw covers on the front of the bezel. They are attached by adhesive, so you may have to dig at it a little bit.
  2. Asus Chromebook C202SA-YS02 Camera Replacement: 步骤 2 中的图像 1,1
    • Unscrew and remove the two Phillips #1 4.5 mm screws that are now visible.
  3. Asus Chromebook C202SA-YS02 Camera Replacement: 步骤 3 中的图像 1,1
    • Using the plastic opening tool, carefully pry off the bezel. It will come off entirely, so be careful not to break it.
  4. Asus Chromebook C202SA-YS02 Camera Replacement, Camera: 步骤 4 中的图像 1,1
    • Using the spudger, disconnect the cable from the camera. The camera will then pop out.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 23
总计 818
