跳转到主内容
Asus Chromebook C202 Motherboard Replacement
你所需要的
  1. Asus Chromebook C202 Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,2 Asus Chromebook C202 Motherboard Replacement, Back Panel: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    Phillips #1 Screwdriver
    $5.49
    购买
    • Remove ten 8 mm Phillips #1 screws from the bottom of the Chromebook using a Phillips #1 screwdriver.
    • Two of the screws are hidden by rubber caps along the rubber rest of the device. Use tweezers to get them out.
  2. Asus Chromebook C202 Motherboard Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    iFixit Opening Tool
    $1.99
    购买
    • Place the plastic opening tool into the edges between the front of the Chromebook and the back of it with the upper scoop of the opening tool facing upward.
    • Push down on the plastic opening tool to unhinge the top portion of the Chromebook from its lower portion. Opening the Chromebook all the way where the display touches the ground helps in opening up the top edge.
    • Use your hand to gently lift the top portion of the Chromebook from the bottom portion of it to avoid damaging the ribbon cables.
  3. Asus Chromebook C202 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Gently disconnect the ribbon cable connecting the trackpad to the motherboard.
    • Gently disconnect the ribbon cable connecting the keyboard to the motherboard.
  4. Asus Chromebook C202 Motherboard Replacement, Wireless Card: 步骤 4 中的图像 1,1
    • Remove the black and white wires from the wireless card.
  5. Asus Chromebook C202 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Unscrew the single 4 mm Phillips #1 screw pinning the wireless card in place.
  6. Asus Chromebook C202 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Gently pull the wireless card away from the motherboard.
  7. Asus Chromebook C202 Motherboard Replacement, Battery: 步骤 7 中的图像 1,3 Asus Chromebook C202 Motherboard Replacement, Battery: 步骤 7 中的图像 2,3 Asus Chromebook C202 Motherboard Replacement, Battery: 步骤 7 中的图像 3,3
    • Pull the latch out on both the Input/Output board as well as the motherboard.
    • Gently remove the ribbon cable connecting the I/O board to the motherboard.
  8. Asus Chromebook C202 Motherboard Replacement: 步骤 8 中的图像 1,3 Asus Chromebook C202 Motherboard Replacement: 步骤 8 中的图像 2,3 Asus Chromebook C202 Motherboard Replacement: 步骤 8 中的图像 3,3
    • Remove two 4 mm Phillips #1 screws from the metal grate connected to the battery.
    • Remove metal grate from battery.
    • Remove six 4 mm Phillips #1 screws from the battery
  9. Asus Chromebook C202 Motherboard Replacement: 步骤 9 中的图像 1,2 Asus Chromebook C202 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Disconnect the battery from the motherboard.
    • Lift battery from the bottom portion of the Chromebook.
  10. Asus Chromebook C202 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Remove the battery from the Chromebook.
  11. Asus Chromebook C202 Motherboard Replacement, Motherboard: 步骤 11 中的图像 1,1
    • Unscrew one 3 mm Phillips #1 screw.
    • Unscrew one 2.5 mm Phillips #1 screw.
    • Unscrew four 4 mm Phillips #1 screws.
  12. Asus Chromebook C202 Motherboard Replacement: 步骤 12 中的图像 1,2 Asus Chromebook C202 Motherboard Replacement: 步骤 12 中的图像 2,2
    • Disconnect the wires that connect the motherboard to the speakers.
    • Disconnect the motherboard from the display.
  13. Asus Chromebook C202 Motherboard Replacement: 步骤 13 中的图像 1,1
    • Lift the motherboard up and out of the chassis.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team 3-1, Passmore Fall 2016 USF Tampa, Team 3-1, Passmore Fall 2016 的会员
USFT-PASSMORE-F16S3G1
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 12
过去 30 天: 66
总计 2,541
