跳转到主内容
Asus Chromebook C202 Keyboard Replacement
你所需要的
  1. Asus Chromebook C202 Keyboard Replacement, Palm Rest: 步骤 1 中的图像 1,1
    • Turn the device over so the bottom is facing up.
    • Remove the ten Phillips #1 8.0 mm screws.
  2. Asus Chromebook C202 Keyboard Replacement: 步骤 2 中的图像 1,2 Asus Chromebook C202 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Carefully use the plastic opening tool to pry the palm rest apart from the bottom cover. Start from one spot and systematically work your way around until the whole palm rest is detached.
  3. Asus Chromebook C202 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Disconnect the two cables that run from the keyboard to the motherboard and from the touch pad to the motherboard.
    • You may have to use a spudger to lift open the respective latches.
  4. Asus Chromebook C202 Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,1
    • Once the cables are disconnected, remove the keyboard from the back panel.
    • Now that the keyboard is disconnected, you can replace it with a new one.
结论
另外一个人完成了本指南。
2指南评论
Is it easy if your replacement keyboard doesn't include the frame? How does the frame attach to the keyboard?
Alexander Pruss - 回复
A replacement keyboard for this Chromebook will contain the palm rest (the frame);
The space between the keys, palm rest, etc., are all composed of a single piece of plastic.
River Saxton -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 29
总计 2,239
