简介
Need to access the inside of your Chromebook, but not sure what to do? This guide will show you how.
你所需要的
Unscrew the seven 4mm screws using a Phillips #0 screwdriver.
Wiggle the plate back and forth to loosen the adhesive under the plate.
Rotate the screwdriver in a counterclockwise direction to remove the screws.
即将完成!
结论
