简介
Having issues with the USB port of your chromebook? This guide will help you fix that.
你所需要的
Unscrew the seven 4mm screws using a Phillips #0 screwdriver.
Wiggle the plate back and forth to loosen the adhesive under the plate.
Rotate the screwdriver in a counterclockwise direction to remove the screws.
Use a Phillips #0 screwdriver to unscrew the two 4mm screws.
Flip up the white tab to remove the white ribbon cable.
即将完成!
结论
