跳转到主内容
Asus Chromebook C201PA-DS02-LG Battery Replacement
你所需要的
  1. Asus Chromebook C201PA-DS02-LG Battery Replacement, Keyboard: 步骤 1 中的图像 1,3 Asus Chromebook C201PA-DS02-LG Battery Replacement, Keyboard: 步骤 1 中的图像 2,3 Asus Chromebook C201PA-DS02-LG Battery Replacement, Keyboard: 步骤 1 中的图像 3,3
    • Use a metal spudger to pry off the two feet closest to the hinge of the laptop.
    • The feet are attached to the laptop by adhesives, therefore they may not stick as well after multiple removals.
  2. Asus Chromebook C201PA-DS02-LG Battery Replacement: 步骤 2 中的图像 1,2 Asus Chromebook C201PA-DS02-LG Battery Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #0 screwdriver to unscrew the six 5mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 6mm screws.
  3. Asus Chromebook C201PA-DS02-LG Battery Replacement: 步骤 3 中的图像 1,2 Asus Chromebook C201PA-DS02-LG Battery Replacement: 步骤 3 中的图像 2,2
    • Use a plastic opening tool to pry the keyboard off the edges of the computer.
    • The edges will make a popping noise.
  4. Asus Chromebook C201PA-DS02-LG Battery Replacement: 步骤 4 中的图像 1,3 Asus Chromebook C201PA-DS02-LG Battery Replacement: 步骤 4 中的图像 2,3 Asus Chromebook C201PA-DS02-LG Battery Replacement: 步骤 4 中的图像 3,3
    • Flip up the white bar that connects the thin white strip using a plastic opening tool.
    • Grab the thin white strip and pull straight back to remove the strip from the connector.
  5. Asus Chromebook C201PA-DS02-LG Battery Replacement: 步骤 5 中的图像 1,3 Asus Chromebook C201PA-DS02-LG Battery Replacement: 步骤 5 中的图像 2,3 Asus Chromebook C201PA-DS02-LG Battery Replacement: 步骤 5 中的图像 3,3
    • Use a plastic opening tool to lift the black bar above the wide black strip in the connector.
    • Grab the wide black strip and pull straight back to remove the strip from the connector.
    • Remove the keyboard by lifting it straight up.
  6. Asus Chromebook C201PA-DS02-LG Battery Replacement, Metal Plate: 步骤 6 中的图像 1,3 Asus Chromebook C201PA-DS02-LG Battery Replacement, Metal Plate: 步骤 6 中的图像 2,3 Asus Chromebook C201PA-DS02-LG Battery Replacement, Metal Plate: 步骤 6 中的图像 3,3
    • Unscrew the seven 4mm screws using a Phillips #0 screwdriver.
    • Wiggle the plate back and forth to loosen the adhesive under the plate.
    • The adhesive will not be the same after removal and more adhesive may be necessary upon reassembly.
    • Rotate the screwdriver in a counterclockwise direction to remove the screws.
    • Do not rest your arm or hand in the adhesive.
  7. Asus Chromebook C201PA-DS02-LG Battery Replacement, Battery: 步骤 7 中的图像 1,3 Asus Chromebook C201PA-DS02-LG Battery Replacement, Battery: 步骤 7 中的图像 2,3 Asus Chromebook C201PA-DS02-LG Battery Replacement, Battery: 步骤 7 中的图像 3,3
    • Use a Phillips #0 screwdriver to unscrew the 4mm screws. Rotate the screwdriver in a counterclockwise direction to undo the screws.
    • Remove the rainbow connector by firmly grasping the rainbow wires and pulling straight back. It will help to brace the motherboard when you pull.
  8. Asus Chromebook C201PA-DS02-LG Battery Replacement: 步骤 8 中的图像 1,2 Asus Chromebook C201PA-DS02-LG Battery Replacement: 步骤 8 中的图像 2,2
    • Use the plastic opening tool to lift up the battery and remove it.
    • Do not dispose of the battery in normal waste. The chemicals inside are toxic. Find out where to dispose of properly in your neighborhood.
结论
Ashley Humpal
于04/18/18注册
185 声望
撰写一个指南
团队
Cal Poly, Team S17-G4, Livingston Spring 2018 Cal Poly, Team S17-G4, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S17G4
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 7
总计 339
