跳转到主内容
Asus Chromebook C201 Palm Rest Assembly Replacement
你所需要的
  1. Asus Chromebook C201 Palm Rest Assembly Replacement, Palm Rest Assembly: 步骤 1 中的图像 1,1
    • Flip the laptop upside down with the rear end of the computer away from you.
  2. Asus Chromebook C201 Palm Rest Assembly Replacement: 步骤 2 中的图像 1,1
    • Remove the two rear rubber feet by using one of the small, blue plastic spudgers.
  3. Asus Chromebook C201 Palm Rest Assembly Replacement: 步骤 3 中的图像 1,1
    • Use the J0 screwdriver to remove the eight 5mm black screws on the bottom of the laptop, which includes the two that were hidden under the rear rubber feet.
  4. Asus Chromebook C201 Palm Rest Assembly Replacement: 步骤 4 中的图像 1,1
    • Turn the laptop on its side. Use a small, blue opening tool to pry the keyboard cover and laptop apart. Begin from the top right, next to the power button, and slowly work your way around to the opposite side until the keyboard cover is detached.
  5. Asus Chromebook C201 Palm Rest Assembly Replacement: 步骤 5 中的图像 1,2 Asus Chromebook C201 Palm Rest Assembly Replacement: 步骤 5 中的图像 2,2
    • Gently flip the keyboard cover away from the laptop. Rest it safely upside down so the cables are not strained and are easily accessible.
  6. Asus Chromebook C201 Palm Rest Assembly Replacement: 步骤 6 中的图像 1,3 Asus Chromebook C201 Palm Rest Assembly Replacement: 步骤 6 中的图像 2,3 Asus Chromebook C201 Palm Rest Assembly Replacement: 步骤 6 中的图像 3,3
    • Use the metal spudger to gently pry up the small tabs that are clamping down on the keyboard cables.
  7. Asus Chromebook C201 Palm Rest Assembly Replacement: 步骤 7 中的图像 1,2 Asus Chromebook C201 Palm Rest Assembly Replacement: 步骤 7 中的图像 2,2
    • Carefully pull the keyboard cables out of the connecting ports that are attached to the motherboard.
  8. Asus Chromebook C201 Palm Rest Assembly Replacement: 步骤 8 中的图像 1,1
    • Remove the keyboard cover and safely place it somewhere face down.
结论
2等其他人完成本指南。
Robert Lawson
于02/09/16注册
841 声望
创作了3篇指南
团队
USF Tampa, Team 2-51, Cagle Spring 2016 USF Tampa, Team 2-51, Cagle Spring 2016 的会员
USFT-CAGLE-S16S2G51
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 774
