跳转到主内容
Asus Chromebook C201 LCD Screen Replacement
你所需要的
  1. Asus Chromebook C201 LCD Screen Replacement, Palm Rest Assembly: 步骤 1 中的图像 1,1
    • Flip the laptop upside down with the rear end of the computer away from you.
  2. Asus Chromebook C201 LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Remove the two rear rubber feet by using one of the small, blue plastic spudgers.
  3. Asus Chromebook C201 LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Use the J0 screwdriver to remove the eight 5mm black screws on the bottom of the laptop, which includes the two that were hidden under the rear rubber feet.
  4. Asus Chromebook C201 LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Turn the laptop on its side. Use a small, blue opening tool to pry the keyboard cover and laptop apart. Begin from the top right, next to the power button, and slowly work your way around to the opposite side until the keyboard cover is detached.
  5. Asus Chromebook C201 LCD Screen Replacement: 步骤 5 中的图像 1,2 Asus Chromebook C201 LCD Screen Replacement: 步骤 5 中的图像 2,2
    • Gently flip the keyboard cover away from the laptop. Rest it safely upside down so the cables are not strained and are easily accessible.
  6. Asus Chromebook C201 LCD Screen Replacement: 步骤 6 中的图像 1,3 Asus Chromebook C201 LCD Screen Replacement: 步骤 6 中的图像 2,3 Asus Chromebook C201 LCD Screen Replacement: 步骤 6 中的图像 3,3
    • Use the metal spudger to gently pry up the small tabs that are clamping down on the keyboard cables.
  7. Asus Chromebook C201 LCD Screen Replacement: 步骤 7 中的图像 1,2 Asus Chromebook C201 LCD Screen Replacement: 步骤 7 中的图像 2,2
    • Carefully pull the keyboard cables out of the connecting ports that are attached to the motherboard.
  8. Asus Chromebook C201 LCD Screen Replacement: 步骤 8 中的图像 1,1
    • Remove the keyboard cover and safely place it somewhere face down.
  9. Asus Chromebook C201 LCD Screen Replacement, LCD Screen: 步骤 9 中的图像 1,2 Asus Chromebook C201 LCD Screen Replacement, LCD Screen: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    • Locate the LCD cable and its connector which is located in the upper left hand corner of the computer. Carefully flip up the tiny tab and safely remove the cable using precision tweezers.
  10. Asus Chromebook C201 LCD Screen Replacement: 步骤 10 中的图像 1,2 Asus Chromebook C201 LCD Screen Replacement: 步骤 10 中的图像 2,2
    • Disconnect the black and white cables located near the screen hinge.
  11. Asus Chromebook C201 LCD Screen Replacement: 步骤 11 中的图像 1,2 Asus Chromebook C201 LCD Screen Replacement: 步骤 11 中的图像 2,2
    • Remove the 6, 4mm silver screws from the hinges attaching the LCD to the laptop using the J0 Phillips screwdriver.
  12. Asus Chromebook C201 LCD Screen Replacement: 步骤 12 中的图像 1,1
    • Turn the hinges to an upright position.
  13. Asus Chromebook C201 LCD Screen Replacement: 步骤 13 中的图像 1,2 Asus Chromebook C201 LCD Screen Replacement: 步骤 13 中的图像 2,2
    • Carefully pop the LCD screen assembly out of the laptop case.
  14. Asus Chromebook C201 LCD Screen Replacement: 步骤 14 中的图像 1,2 Asus Chromebook C201 LCD Screen Replacement: 步骤 14 中的图像 2,2
    • Remove the silver cover.
    • Make sure to put the cover back in right side (longer side) up when re-installing
  15. Asus Chromebook C201 LCD Screen Replacement: 步骤 15 中的图像 1,2 Asus Chromebook C201 LCD Screen Replacement: 步骤 15 中的图像 2,2
    • Use a blue plastic spudger to snap the LCD cover off, working the spudger around the perimeter and completely remove the cover.
  16. Asus Chromebook C201 LCD Screen Replacement: 步骤 16 中的图像 1,1
    • Remove the 4, 3mm silver corner screws holding in the LCD.
  17. Asus Chromebook C201 LCD Screen Replacement: 步骤 17 中的图像 1,2 Asus Chromebook C201 LCD Screen Replacement: 步骤 17 中的图像 2,2
    • Remove the left hinge by unscrewing the two 3mm large Phillips head screws.
    • Unscrew the one 3mm small Phillips head screw.
  18. Asus Chromebook C201 LCD Screen Replacement: 步骤 18 中的图像 1,2 Asus Chromebook C201 LCD Screen Replacement: 步骤 18 中的图像 2,2
    • Carefully lift the screen. Gently unravel and unplug the LCD cord.
结论
10等其他人完成本指南。
Taylor Allen
于02/09/16注册
327 声望
撰写一个指南
团队
USF Tampa, Team 2-51, Cagle Spring 2016 USF Tampa, Team 2-51, Cagle Spring 2016 的会员
USFT-CAGLE-S16S2G51
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 3,848
