跳转到主内容
Asus Chromebook C101P Screen Replacement
你所需要的
  1. Asus Chromebook C101P Screen Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Flip the Chromebook so that the bottom is facing up.
    • Remove the nine T5 Torx screws.
  2. Asus Chromebook C101P Screen Replacement: 步骤 2 中的图像 1,1
    • Remove the four rubber grips on the bottom side of the Chromebook using an opening tool.
  3. Asus Chromebook C101P Screen Replacement: 步骤 3 中的图像 1,1
    • Remove the four black screws where the rubber grips were.
  4. Asus Chromebook C101P Screen Replacement: 步骤 4 中的图像 1,2 Asus Chromebook C101P Screen Replacement: 步骤 4 中的图像 2,2
    • Reorient the Chromebook so the right side is facing upwards.
    • Wedge an opening tool or spudger between the keyboard (upper case) and the lower case of the bottom portion of the Chromebook.
  5. Asus Chromebook C101P Screen Replacement: 步骤 5 中的图像 1,3 Asus Chromebook C101P Screen Replacement: 步骤 5 中的图像 2,3 Asus Chromebook C101P Screen Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the large ribbon cable.
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the small ribbon cable.
    • Separate the keyboard from the rest of the laptop.
  6. Asus Chromebook C101P Screen Replacement, Screen: 步骤 6 中的图像 1,2 Asus Chromebook C101P Screen Replacement, Screen: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    • Detach the the screen cables from the motherboard using a pair of tweezers.
    • Peel off the tape or seal to easily remove the screen cables.
  7. Asus Chromebook C101P Screen Replacement: 步骤 7 中的图像 1,2 Asus Chromebook C101P Screen Replacement: 步骤 7 中的图像 2,2
    • Remove the Phillips 00 screws from the hinges.
  8. Asus Chromebook C101P Screen Replacement: 步骤 8 中的图像 1,1
    • Angle the hinge as shown and use a T5 Torx screwdriver to remove the hinge screws.
  9. Asus Chromebook C101P Screen Replacement: 步骤 9 中的图像 1,2 Asus Chromebook C101P Screen Replacement: 步骤 9 中的图像 2,2
    • Pry open the hinge by using the iFixit opening tool.
  10. Asus Chromebook C101P Screen Replacement: 步骤 10 中的图像 1,1
    • Use the iFixit opening tool to pop out the black rubber grips near the bottom of the screen.
    • Use a Phillips 00 screwdriver to remove the screws beneath the rubber grips.
  11. Asus Chromebook C101P Screen Replacement: 步骤 11 中的图像 1,3 Asus Chromebook C101P Screen Replacement: 步骤 11 中的图像 2,3 Asus Chromebook C101P Screen Replacement: 步骤 11 中的图像 3,3
    • Use the iFixit opening tool to pry around the screen.
    • Use the space between the screen and the hinge to prop it up.
    • Once open, slide the wires that are in the hinge out. The screen should now be fully detached from the case.
结论
2等其他人完成本指南。
Dan Sysopha
于10/25/19注册
369 声望
创作了2篇指南
团队
UMass Dartmouth, Team S1-G2, O'Connell Fall 2019 UMass Dartmouth, Team S1-G2, O'Connell Fall 2019 的会员
UMASSD-O'CONNELL-F19S1G2
2 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 2,588
