简介
Is your computer experiencing problems with loading or booting up? Consider using this guide to replace the motherboard of your device.
你所需要的
Remove the 5mm screw using a Phillips #1 screwdriver.
Use the iFixit opening tools to remove the RAM panel.
Remove the RAM cover from the bottom of the keyboard.
Remove the 5mm screw keeping the panel in place using a Phillips #1 screwdriver.
Work the pry tool along the edge to finish removal.
Unscrew the two 7mm screws marked with an engraved "K" using a #1 Phillips screwdriver.
Close the laptop and place it upside down.
Remove the twelve 7mm screws using a Phillips #1 screwdriver.
2等其他人完成本指南。
