跳转到主内容
Asus A53U-ES21 Motherboard Replacement
你所需要的
  1. Asus A53U-ES21 Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 Asus A53U-ES21 Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure the laptop is off.
    • Flip the laptop upside down so that the battery is facing you.
  2. Asus A53U-ES21 Motherboard Replacement: 步骤 2 中的图像 1,2 Asus A53U-ES21 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Move the two sliders towards the outer edge of the laptop.
    • Pull the battery out with your left hand while holding the right slider.
  3. Asus A53U-ES21 Motherboard Replacement, Optical Drive: 步骤 3 中的图像 1,3 Asus A53U-ES21 Motherboard Replacement, Optical Drive: 步骤 3 中的图像 2,3 Asus A53U-ES21 Motherboard Replacement, Optical Drive: 步骤 3 中的图像 3,3
    • Remove the 5mm screw using a Phillips #1 screwdriver.
    • Use the iFixit opening tools to remove the RAM panel.
  4. Asus A53U-ES21 Motherboard Replacement: 步骤 4 中的图像 1,3 Asus A53U-ES21 Motherboard Replacement: 步骤 4 中的图像 2,3 Asus A53U-ES21 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Remove the 7mm screw using a Phillips #1 screwdriver.
    • Pull the optical drive out from the side of the laptop.
  5. Asus A53U-ES21 Motherboard Replacement, Keyboard: 步骤 5 中的图像 1,3 Asus A53U-ES21 Motherboard Replacement, Keyboard: 步骤 5 中的图像 2,3 Asus A53U-ES21 Motherboard Replacement, Keyboard: 步骤 5 中的图像 3,3
    • Remove the RAM cover from the bottom of the keyboard.
    • Remove the 5mm screw keeping the panel in place using a Phillips #1 screwdriver.
    • Work the pry tool along the edge to finish removal.
    • Unscrew the two 7mm screws marked with an engraved "K" using a #1 Phillips screwdriver.
  6. Asus A53U-ES21 Motherboard Replacement: 步骤 6 中的图像 1,3 Asus A53U-ES21 Motherboard Replacement: 步骤 6 中的图像 2,3 Asus A53U-ES21 Motherboard Replacement: 步骤 6 中的图像 3,3
    • Orient the computer so the keyboard is facing toward you with the screen at the top.
    • Find the three buttons to depress at top of the keyboard, set in the crack between the casing and the keyboard, highlighted here in red.
    • Use the pry tool to depress the buttons. The keyboard should pop out.
  7. Asus A53U-ES21 Motherboard Replacement: 步骤 7 中的图像 1,3 Asus A53U-ES21 Motherboard Replacement: 步骤 7 中的图像 2,3 Asus A53U-ES21 Motherboard Replacement: 步骤 7 中的图像 3,3
    • Fold the keyboard out towards you. It should still be connected by a ribbon to the rest of the computer.
    • Gently use the opening tool to lift the black piece holding the ribbon down and remove the ribbon.
    • The black piece should cover the white line on the ribbon when it is replaced.
  8. Asus A53U-ES21 Motherboard Replacement, Motherboard: 步骤 8 中的图像 1,1
    • Close the laptop and place it upside down.
    • Remove the twelve 7mm screws using a Phillips #1 screwdriver.
  9. Asus A53U-ES21 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Remove the two 2mm screws using a Phillips #1 screwdriver.
  10. Asus A53U-ES21 Motherboard Replacement: 步骤 10 中的图像 1,2 Asus A53U-ES21 Motherboard Replacement: 步骤 10 中的图像 2,2
    • Pull the connectors away from the wireless card using the plastic opening tools.
    • Pull the white connector from its socket in the RAM panel.
  11. Asus A53U-ES21 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Flip the laptop over again, open it, and unscrew the three 7mm screws using a Phillips #1 screwdriver.
  12. Asus A53U-ES21 Motherboard Replacement: 步骤 12 中的图像 1,3 Asus A53U-ES21 Motherboard Replacement: 步骤 12 中的图像 2,3 Asus A53U-ES21 Motherboard Replacement: 步骤 12 中的图像 3,3
    • Gently pull the tan flap off of the cable using the plastic opening tool.
    • Push the tan piece towards the cable and release it using the plastic opening tool.
    • Pull the black flap off of its connector.
  13. Asus A53U-ES21 Motherboard Replacement: 步骤 13 中的图像 1,2 Asus A53U-ES21 Motherboard Replacement: 步骤 13 中的图像 2,2
    • Separate the front plate of the laptop from the back using the plastic opening tool.
  14. Asus A53U-ES21 Motherboard Replacement: 步骤 14 中的图像 1,3 Asus A53U-ES21 Motherboard Replacement: 步骤 14 中的图像 2,3 Asus A53U-ES21 Motherboard Replacement: 步骤 14 中的图像 3,3
    • Remove the single 7mm screw from the motherboard using a Phillips #1 screwdriver.
    • Pull to two shown cables from their sockets using the plastic opening tools.
    • Gently remove the motherboard from the laptop.
结论
2等其他人完成本指南。
Chase Poirier
于10/23/18注册
544 声望
创作了5篇指南
团队
UMass Dartmouth, Team S1-G3, Simcock Fall 2018 UMass Dartmouth, Team S1-G3, Simcock Fall 2018 的会员
UMASSD-SIMCOCK-F18S1G3
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 36
总计 915
