跳转到主内容
Asus 1015E-DS03 Screen Replacement
你所需要的
  1. Asus 1015E-DS03 Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Hold the laptop using both hands with the battery facing upwards.
  2. Asus 1015E-DS03 Screen Replacement: 步骤 2 中的图像 1,1
    • Push the two tabs located below the battery in towards each other using your thumbs.
  3. Asus 1015E-DS03 Screen Replacement: 步骤 3 中的图像 1,1
    • Push the battery upwards and out of the laptop as shown.
  4. Asus 1015E-DS03 Screen Replacement: 步骤 4 中的图像 1,1
    • Continue to push the battery upwards until it is completely separated from the laptop as shown.
  5. Asus 1015E-DS03 Screen Replacement, Front Screen Case: 步骤 5 中的图像 1,1
    • Push up on the back of the tabs that cover the hinges connecting the screen to the base of the laptop.
    • While pushing up on the back of the tabs, insert the spudger into the opening created from pushing on the tabs until the tab detaches.
  6. Asus 1015E-DS03 Screen Replacement: 步骤 6 中的图像 1,2 Asus 1015E-DS03 Screen Replacement: 步骤 6 中的图像 2,2
    • Once the case has been separated from the laptop, pull the case off completely, using the plastic opening tool or your fingers.
    • You will hear popping noises which are to be expected.
  7. Asus 1015E-DS03 Screen Replacement: 步骤 7 中的图像 1,1
    • When the screen case has been successfully removed, the laptop should resemble the photo shown here.
  8. Asus 1015E-DS03 Screen Replacement, Screen: 步骤 8 中的图像 1,1
    • Unscrew the 3 mm screws (4) using a #0 Phillips head screwdriver.
  9. Asus 1015E-DS03 Screen Replacement: 步骤 9 中的图像 1,2 Asus 1015E-DS03 Screen Replacement: 步骤 9 中的图像 2,2
    • Lift the screen away from the computer.
    • Be careful removing the screen, as the left side is still connected to the computer.
  10. Asus 1015E-DS03 Screen Replacement: 步骤 10 中的图像 1,2 Asus 1015E-DS03 Screen Replacement: 步骤 10 中的图像 2,2
    • Remove the wire that is glued to the back of the screen with your fingers.
    • Remove the tape covering the connection port.
  11. Asus 1015E-DS03 Screen Replacement: 步骤 11 中的图像 1,1
    • Separate the screen from the computer by gently pulling it out.
  12. Asus 1015E-DS03 Screen Replacement: 步骤 12 中的图像 1,1
    • Upon removal, the computer should look like this picture.
结论
2等其他人完成本指南。
Becca Day
于03/23/16注册
297 声望
创作了2篇指南
团队
Clemson, Team 7-4, Benson Spring 2016 Clemson, Team 7-4, Benson Spring 2016 的会员
CLEM-BENSON-S16S7G4
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 21
总计 632
