你所需要的
以红色和橘色标记的为散热模组的固定螺丝。
虽然它们的尺寸一样但仍然建议按顺序摆放螺丝防止混淆
黄色标记的为供电和信号模块,使用塑料撬棍断开
使用相同的撬棒平侧撬开两个模具。 旧的导热膏可能会增大拆卸难度。
小心地卸下最左侧(蓝色边框中)隐藏在塑料下的显示屏线。
小心的取下最右侧(粉色边框中)隐藏在塑料下的Wifi线(白色和黑色)。
这时,我们才可以卸下散热模组。
如图可以看到应该涂抹硅脂的位置,确保将其涂抹在相同的表面上。
两个容易遗漏的部分已标记
作者使用了 70% 的酒精、纸巾和撬棒的平头来去除旧硅脂。
作者使用塑料撬棒将硅脂涂抹在芯片上,以确保完全接触。
按相反顺序来重新组装设备
按相反顺序来重新组装设备
12等其他人完成本指南。
由衷感谢以下译者:
89%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
6条评论
Did you manage to get an answer to this? I didn't use metal tweezers but my laptop won't turn on and it's blinking as if it's trying to run but it can't!
Open up chips and look if there are cracks on chips, if there are, then you got a dead chip.
I followed this and even used ifixit tools and now my laptop won't boot. No bios, no charge light, no cpu light, no fans. I followed it exactly, grounded myself, didn't touch the motherboard, didn't even get up as to not accidentally generate static, worked on concrete and a wooden table, none of the connections are loose or damaged. It just won't turn on. What happened and how can I fix it?
I’d go in and check for any connections on the motherboard that you may have missed and also look out for any broken ones. Try reseating any connections such as the battery connector and display cable.
