跳转到主内容
Astro C40 TR Joystick Replacement
你所需要的
  1. Astro C40 TR Joystick Replacement, Joystick: 步骤 1 中的图像 1,1
    • Unplug your controller from the video game console.
    • Turn the wireless mode off if it is activated on your controller.
  2. Astro C40 TR Joystick Replacement: 步骤 2 中的图像 1,3 Astro C40 TR Joystick Replacement: 步骤 2 中的图像 2,3 Astro C40 TR Joystick Replacement: 步骤 2 中的图像 3,3
    • Use an H.20 Hexagonal screwdriver to loosen the two screws on each joystick's side.
    • Remove the face cover of the joystick by flipping the controller on its side.
    • Don't panic if the joystick falls off! It can be placed back on.
  3. Astro C40 TR Joystick Replacement: 步骤 3 中的图像 1,3 Astro C40 TR Joystick Replacement: 步骤 3 中的图像 2,3 Astro C40 TR Joystick Replacement: 步骤 3 中的图像 3,3
    • Use the 30mm TORX Screwdriver to remove the screws from the module.
    • Push on the top frame until it pops off of the module.
    • If you have a whole new joystick module, you can skip to step 6.
  4. Astro C40 TR Joystick Replacement: 步骤 4 中的图像 1,3 Astro C40 TR Joystick Replacement: 步骤 4 中的图像 2,3 Astro C40 TR Joystick Replacement: 步骤 4 中的图像 3,3
    • Connect the base frame replacement to the joystick module.
    • Insert the top frame on the module until it clicks back together.
  5. Astro C40 TR Joystick Replacement: 步骤 5 中的图像 1,3 Astro C40 TR Joystick Replacement: 步骤 5 中的图像 2,3 Astro C40 TR Joystick Replacement: 步骤 5 中的图像 3,3
    • Reassemble the joystick module and plug it back into the controller.
    • Make sure the replacement and base frame are tightly screwed together.
    • Align the module and controller as you put joystick back together.
  6. Astro C40 TR Joystick Replacement: 步骤 6 中的图像 1,2 Astro C40 TR Joystick Replacement: 步骤 6 中的图像 2,2
    • Reassemble the controller by placing the face cover back on.
    • Tighten the screws on the face cover with the H.20 Hexagonal Screwdriver.
    • If it's difficult to tighten the screws, don't force it. The joystick and controller are probably not aligned correctly!
  7. Astro C40 TR Joystick Replacement: 步骤 7 中的图像 1,1
    • Recalibrate the controller so the new joystick can be detected by the console.
    • Connect the controller to the console and activate wire-connect mode by clicking the controller's top right corner.
    • Push the button on the back of the controller. Hold it until the controller vibrates. Release the button and repeat.
结论
Pan
于09/13/21注册
145 声望
撰写一个指南
团队
York University, Team E-21, Melo-Thaiss Fall 2021 York University, Team E-21, Melo-Thaiss Fall 2021 的会员
YORK-MELO-THAISS-F21SEG21
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 20
过去 30 天: 93
总计 3,223
